Problem with root function from 14 to Prime2
dsanchez1
Hello , i have a doubt, in the right side math14 i have a root function and im triying to do the same in the left side with prime 2.0, someone can help me please? Thanks so much.
LucMeekes
(To:dsanchez1)
In Mathcad 14 you have the array h defined with 11 elements.
In Prime you have defined h defined as a range variable. I guess that's what prime is complaining about.
Try changing the definition of h to h[i:7+i
(which should display like:
And I fail to see a definition for sigma...
Hello LucMeekes, i tried but doesnt work, i would like to enter the same collections of values as M14 but i cant find the correct form, till now only work putting only one value in h sub i
RichardJ
(To:dsanchez1)
It's hard to tell from a picture, but it looks like you have a literal subscript on h, not a vector subscript. You should get the vector subscript by typing h[i:7+i
LucMeekes
(To:RichardJ)
It's definitely a literal subscript, if I may base it on the looks of Prime 3.1.
Dailos, You need to define both h and k in the array form. That is
by typing h[i and k[i respectively,
and NOT use the 'subscript' button from the ribbon (or type [CTRL _]).
Here's my result:
