Problem with symbolic simplification
rgunwaldsen
I'm frustrated   trying to simplify   results from   symbolic   engine (new or legacy). i have tried multiple symbolic   options.
For some reason, if I go in and   manually do an   equate, stuff sort of works?
Prime 6 file.
1 ACCEPTED SOLUTION
LucMeekes
(To:rgunwaldsen)
Are all your t's of the same label?
6 REPLIES 6
LucMeekes
(To:rgunwaldsen)
It's a known fact that the output of the  symbolic processor is hard  to control.
In your case maybe the keyword  'collect, exp' helps.
rgunwaldsen
(To:LucMeekes)
Thanks for lookig, Luc -- but your suggestion does not work.
Since you're running   Mathcad 11, can the Maple  engine   do a better job?
LucMeekes
(To:rgunwaldsen)
Don't have it at hand.
Try 'assume,t>0'
rgunwaldsen
(To:LucMeekes)
Sadly, no again.
But again, thanks for the suggestions.
Roger
LucMeekes
(To:rgunwaldsen)
rgunwaldsen
(To:LucMeekes)
Bingo!
The first expression has the first t as "automatic" and the  second t as  "variable"..
Changed the first t to "variable", and all is well.
Thanks again,
Roger
