Problems with tables - Mathcad does not print table with more that 10 lines
JM2
When I read some data from a file or when I create a a matrix or a vector on more that 10 rows, whatever the calculation I do on this table, Mathcad cannot return the values : I cannot see the results for any table having more than 10 rows.
Does anybody has this problem?
24-Ruby V
(To:JM2)
Are you using real Mathcad or the mediocre Prime?
Note that in both versions you can resize the matrix to show more or less elements. In case of Prime this (and especially also scrolling in a matrix) is implemented very silly and cumbersome.
If you are not able to resize, you may send a sample sheet to show the problem.
VladimirN
24-Ruby II
(To:JM2)
Please provide your example worksheet.
