Program continue after returning a string
JohnRudnicki
Is there a way to have a program return a message but then continue executing? For example, in the attached program I want it to print the message "The ball does not reach the basket" but continuing executing rather than stopping, as happens with "return".
1 ACCEPTED SOLUTION
Use the 'on error' programming construct. See help or attached (Mathcad 11 .mcd worksheet)
Stuart
2 REPLIES 2
Stuart
Thanks. jwr
