Programmatically Creating a Nested Array
SOLVED
Participant
Hi MathCad Experts,
Step 1 I have a 3x3 matrix t[1] with 1's and 0's . I want to insert another 3x3 matrix "One" into U if the element of t[1] is 1 other insert 3x3 matrix zero as a Nested Array.
Step 2 Convert to a Matrix.
I have not done this previously so I would like your suggests/help.
Thanks.
Tags (3)
Re: Programmatically Creating a Nested Array
Here is the flattening part, too, unnesting the matrices
See if the attached would help
Ahhh... Yes... Thanks.
Russell
