Programming a loop to seek specific cells from an excel file
SOLVED
Amethyst
Hello folks,
I have an Excel sheet in which caloric properties for real gas are calculated. One of the values is only delivered when a VB code is executed in Excel. I strongly suspect that these are in a data map of sorts which is what I'm after. Since I can't access this table (the guy who created this sheet has left long since) I'd like to "push" the appropiate button in Excel from a Mathcad loop repeatedly and read out the data in a specific cell.
Does anybody know whether this is feasible?
Raiko
Re: Programming a loop to seek specific cells from an excel file
Here is a sample of automating Excel.  It enters some values in cells, runs a macro called "test", then fetches a cell value.
For a sample of automating Mathcad Prime look at "Re: Mathcad Prime Interface / API" in section of Top Kudoed Posts.
Do you want someone to do the automation for you, if you can share the sheets?
using System;
using System.Windows.Forms;
using Excel = Microsoft.Office.Interop.Excel;
namespace ExcelMathCad
public partial class Form1 : Form
public Form1()
InitializeComponent();
private static Excel.Application MyApp = null;
private static Excel.Workbook MyBook = null;
private static Excel.Worksheet MySheet = null;
private int lastRow;
private void button1_Click(object sender, EventArgs e)
MyApp = new Excel.Application();
MyApp.Visible = true;
MyBook = MyApp.Workbooks.Open(@"D:\\Prime\\Questions\\Book1.xlsm");
MySheet = (Excel.Worksheet)MyBook.Sheets[1]; // Explicit cast is not required here
lastRow = MySheet.Cells.SpecialCells(Excel.XlCellType.xlCellTypeLastCell).Row;
lastRow += 1;
MySheet.Cells[lastRow, 1] = "Six";
MySheet.Cells[lastRow, 2] = 14;
MySheet.Cells[lastRow, 3] = "Test";
MySheet.Cells[lastRow, 4] = 30.9;
MyApp.Run("Test");
double val = MySheet.Cells[1, 4].Value;
MyBook.Save();
MyBook.Close();
MyApp.Quit();
System.Runtime.InteropServices.Marshal.ReleaseComObject(MySheet);
MySheet = null;
System.Runtime.InteropServices.Marshal.ReleaseComObject(MyBook);
MyBook = null;
System.Runtime.InteropServices.Marshal.ReleaseComObject(MyApp);
MyApp = null;
Hi Raiko
It  is possible to automate both Mathcad and Excel using the API of both.  This includes running Excel macros.
From the web
"Is there any api for executing a macro code of an excel? I don't want to use office interop and I don't want to recode using aspose, I have lot of existing macros I just want to know if there's an api that can do that?
To run a macro, you must create an environment in which the macro can run. To create such an environment you need to automate Excel. You can do this in an Excel add-in or in a standlone application in .NET or in Delphi, VB6, VC++ or other language. After you instantiate the Excel.Application object, you need to call the method it provides - RunMacro."
The other option is to run the macro by hand and use Mathcad's Readexcel component to  read the values into Mathcad.
using System;
public Form1()
lastRow += 1;
MyApp.Run("Test");
MyBook.Save();
MyBook.Close();
MyApp.Quit();
MySheet = null;
MyBook = null;
MyApp = null;
Thank you Terry for the code. Will try it in Mathcad 15.
However, I can't share the Excel sheet.
Raiko
