Programming with units
drgriffin
How well does 14 handle units in programs ? I know earlier versions didn't do so well.
8 REPLIES 8
RichardJ
(To:drgriffin)
The only real problem I can think of with units in programs is returning multiple values with different units. In this respect Mathcad 14 is the same as before. The only way to return multiple values is in an array, and mixed units are not allowed in arrays.
Richard
>arrays.
Richard
Second problem - if(...,kg,m)
Val
http://twt.mpei.ac.ru/ochkov/v_ochkov.htm
Well, that's just a problem with SUC. It's not specific to programming.
Richard
>Richard
OK!
kg if ...
m otherwise
Val
So if you're returning multiple values with different units from your program, the last step has to be to divide by the appropriate units to make all the values unitless. Then you have to re-attach (multiply) those units after exiting the program.
Preston
It's not specific to programming too.
Val
True. I could write a function with no programming that had the same problem.
Richard
>Richard
It is only one programming tool in Mathcad - Add Line operator.
Local vars we see in the summ operator (i)
While has until operator analog...
Val
