[Q] Serious API troubling between Python and Mathcad prime - SetMatrixElement(), GetMatrixElement()
Participant
Dear sir,
Now I am solving a design optimization problem using Mathcad prime 6.0 through python API. I uses comtypes library to deal with API programming in my Python code.
In python code, I can set a single variable easily and vice verse. However, I could not set a matrix and get it from Mathcad.
I really love to exchange variables which whether it is a real single variable or matrix between Python and Mathcad.
I could not find any solution method for this trouble.
Please help me with this issue. I really want to make them exchangeable for reproducible research work. It is not commercial but academic.
With my best regards,
JW
The following is the python code to call and set matrix in Mathcad. Two functions are defined. The first(set_element) is  to set the elements of the matrix in Mathcad but the second(get_element) is to get the element of the matrix from Mathcad.
   import comtypes.client as CC
   import comtypes
    def set_element(self, row_index, column_index, value):
        """ Sets the value of an element in the Matrix """
        if self.object is not None:
            try:
                row, col = int(row_index), int(column_index)
                self.object.SetMatrixElement(row, col, value)
            except ValueError:
                raise ValueError("Matrix maths can only use numerical values")
            except:
                raise Exception("COM Error setting element value")  # Hidden for above @FIXME
        else:
            raise TypeError("Matrix must first be created")
    def get_element(self, row_index, column_index):
        """ Fetches the value of an element in the Matrix """
            try:
                self.object.GetMatrixElement(row, col)
            except ValueError:
            except:
                raise Exception("COM Error fetching element value")
        else:
Re: [Q] Serious API troubling between Python and Mathcad prime - SetMatrixElement(), GetMatrixElemen
I remember there were a few threads in this forum about exchanging matrices via the API in the past but I am not sure if there ever was a satisfying solution. You may try the search function in the forum to find those threads.
While not specifically covering python, maybe this post can be of help: https://community.ptc.com/t5/PTC-Mathcad/Using-Matrix-with-Prime-3-1-API/m-p/313195/highlight/true#M...
I really appreciate it.  I will look at it.
Is there anybody who can reach https://www.ptc.com/en/support/article/CS301830?
The name of article is 'Article - CS301830 How to set a matrix element value using API SetMatrixElement() and SetMatrixValue() in Mathcad Prime'.
It is the right thing for me.
Please help me look at the article.
JW
Here you are, but the "article" just consists of the code example which you can also find in the thread I linked to in my first answer.
------------------------------------------------------- snip -------------------------------------------------
Modified: 28-Feb-2019
Applies To
  • Mathcad Prime 3.1 to 5.0
  • API
Description
  • How to set a matrix element value using API SetMatrixElement() and SetMatrixValue()
Resolution
It is ridiculous.  Even though I coded like the c++ in the above, it still does not work. I do not know where I start from.
<Functions>
    def create_matrix(self, rows, columns):
        """ Creates a Mathcad matrix """
        try:
            rows, columns = int(rows), int(columns)
            self.shape = (rows, columns)
            self.object = self.__ws.CreateMatrix(rows, columns)
            return True
        except ValueError:
            raise ValueError("Matrix dimensions must be integers")
            return False
        except:
            raise Exception("COM Error creating Mathcad matrix")
            return False
            try:
                self.object.SetMatrixElement(row, col, value)  # @FIXME
            except ValueError:
            except:
        else:
<Main>
    A = Matrix()
    A.create_matrix(2,2)
    A.set_element(1,1,3.0)
<Error messege>
Loading Mathcad
Traceback (most recent call last): File "//Mac/Home/Downloads/MathcadPy-master/MathcadPy/Application.py", line 361, in <module> A.set_element(1,1,3.0) File "//Mac/Home/Downloads/MathcadPy-master/MathcadPy/Application.py", line 312, in set_element self.object.SetMatrixElement(row, col, value) # @FIXME OSError: exception: access violation writing 0x0000000000000001
