Quadratic equation and a lsolve function
ValeryOchkov
There is a quadratic algebraic equation. Is it possible, according to its coefficients a, b, and c, to form a system of two linear algebraic equations with the same roots as the quadratic equation?
Others word! Can I use the lsolve function for the solving a quadratic algebraic equation?
Equally unfair but a little bit nicer
7 REPLIES 7
I used to work with older (back then) engineers who were adept at EXCEL and adverse to Mathcad,  We could get curve fits to polynomials by "creating" a column with the values for the other powers and using the EXCEL function "linest".  A similar trick should work for lsolve; that trick used in a least square matrix solver in Prime 4 is attached.
LucMeekes
(To:Fred_Kohlhepp)
Nice exercise Fred, but I don't see it solve the quadratic, or am I missing something?
LucMeekes
(To:ValeryOchkov)
I'm afraid not, Valery:
Yes, we can! Smiley LOL
Здравствуйте. Решал задачу в mathCad: методом наименьших квадратов рассчитать коэффициенты уравнения по результатам решения показаного в таблице полного двохуровневого трьохфакторного плана ПФЕ. Праподаватель сказал что есть ошибки, больше ничего не сказал, поможете?
I think it will be better to write your question in English and put it here as new message!
And better to have comments in your Mathcad-sheet in English!
