READEXCEL problem in MC15
Raiko
Hi folks,
I have an Excel file consisting of 26 work sheets full of data. With the READEXCEL command I'd like to read them in, however:
  1. READEXCEL doesn't read all the work sheets, but from 0 through 8
  2. However, backwards I'm able to read from 26 through 10
I have checked whether there are some format problems on the sheet 9 or 10 but to no avail. This really puzzles me. Is there some kind of bug or does anybody see a flaw in the attached MC15 file?
Sorry, but it has to be in MC15 otherwise the READEXCEL command doesn't execute.
Thanks in advance
Raiko
MikeArmstrong
(To:Raiko)
It's because you have called your sheet ch 9 - CH 9.
Change it and it works.
Mike
MikeArmstrong
(To:Raiko)
Mike
Thank you Mike. Must have been a case of code blindness-the weekend is nearing
Raiko
MikeArmstrong
(To:Raiko)
Not a problem.
Took me a while to spot it. As you said, its nearly the weekend
Mike
