Random range variable
ptc-5377589
How can I define a range variable when the variables are not necessarily in defined pattern? I have got round the issue in the attached using a lookup expression from a table but can I not define d as a comma separated list? d:= 12,16,20,24,30,36 ? to simplify the expression?
OK, this is better, thanks for your help Andy
Capture.JPGr
What do you want to do with the range variable once it is created?
the FOR command in the programming toolbar gives a structure:
for <variable> <for each value in> LIST
that will allow you to produce a program as :
regards
Andy
Thanks Andy, I've been trying since you posted but I can't see how I actually use that in my programme? In the end I'm trying to avoid using a lookup table and using a for statement similar to yours! Alas my understanding is failing!
Capture.JPGr
Rather than a lookup table, use a vector.
Indeed. In this instance, getting the vector should be a straight forward matter of using submatrix to extract it from Table1.
d:=submatrix (Table1, 1, rows (Table1)-1,1,1)
Stuart
