Range Variable Function
KarlFleischer
I am looking for a way to create a points file using a function that I can bring into a solid modeler that can be used to create a cam surface. As a simple example, for a circle, I would want an angle in the first column, an x coordinate R*sin(Theta) in the second column and a y coordinate R*cos(Theta) in the second column. I may want to add a fourth column with a function for the profile in the z direction. Thanks, Karl.
LucMeekes
(To:KarlFleischer)
Something like this?
Prime 4 file is attached.
For a circular cam it's pretty easy.  This should do it.  Other cams are often piecewise, and I've found no simple solutions other than just stepping through each section.
KarlFleischer
(To:DJF)
This solution is good also. The augment function is very helpful. Thanks!
LucMeekes
(To:KarlFleischer)
This is what I had in mind. Thank you very much!
