Hi everyone,
I am trying to do some calculations using Mathcad 14 but I have a problem where variable of a function can't be assigned to a range of variables.
I am attaching the sheet, it would be appreciated if one could point the error.
Yigit Turgut wrote:
Hi everyone,
Yigit,
Stuart
Yigit Turgut wrote:
Hi everyone,
Yigit,
Stuart
Or he could just use your vec function to create a vector instead of using a range variable.
Mike
Thanks for the reply that seems to work for that far but I have a following problem where an index of an array can not be assigned as a matrix, for detail please see the attached file.
Sorry for the description, the problem is that the expression tries to take square root of the matrix which cholesky decomposition seem to be helpful.
