Range variables
Highlighted
Range variables
Hi! I am new in using this wonderful software and Iam eager to use it as better as possible. I am trying to produce a table of present values of 480 payments payable monthly at 2.5% annual rate. I have calculated based on the example provided in the chapter 2 page 2 of the user's guide of Mathcad standard, but there is one column showing all the payments from 0 to 479. How can I produce a table with more than one column and in several rows, to say 1 row of 4 columns containing 12 payments, that is 10 rows of 4 column containing 12 payments and the column should begin with 1?
Jose
5 REPLIES 5
Highlighted
Range variables
Highlighted
Range variables
I am sorry you did not understand. let see for example, How can I modified the table produce in the example number 4 in the page 16 of the chapter 2 of the user's guide mathcad standard so I can produce more than one column instead of one.
Jose.
Highlighted
Range variables
Thank you for your additional clues. The previous attempt to answer was very brave. Try this one.
Highlighted
Range variables
yes, you are. My question now is How can modified the table to show 10 goups of 12 of only one interest rate so it can be printed in one sheet instead of one long column. I know that by making i=0 will produce only the rate 00250.
For example
0 0.998 25 0.948
1 0.996 26 0.946
2 0.994 27 0.944
3 0.992 26 0.942
4 0.990 27 0.940
5 0.988 28 0.938
6 0.986 28 0.936
7 0.984 (etc,..)
8 0.982
9 0.980
10 0.978
11 0.976
12 0.974
13 0.972
14 0.970
15 0.968
16 0.966
17 0.964
18 0.962
19 0.960
20 0.958
21 0.956
22 0.954
23 0.952
24 0.950
Thans,
Jose
Highlighted
Range variables
Well, it's not pretty.
