I have to do some calculations within one sheet which I have to repeat a couple of times.
For example:
Input:
A
Calculations:
B = A + 1
C = A * 3
D = B / C
And then I want to publish both B, C and D.
My (printable left side) should look like:
A = x B = x C = x D = x
The formulas need to be located somewhere on the right side page.
But I want to be able to re-use the formulas so my left page will look like:
A.1 = x B.1 = x C.1 = x D.1 = x
A.2 = x B.2 = x C.2 = x D.2 = x
and I don't want to have to copy all the formulas all the time.
I know I can work with matrices, but that's not what I want. I really want to address a function and return the results from there.
Is this possible? And if so, how do I do this?
Thanks in advance for your replies.
Thanks both for your suggestions.
My problem is however that this doesn't really work, as not all my results are directly based on 1 input parameter.
What I have now is:
P(A):=A+1 Q(P):= P-2 R(Q):=Q^2
A.1:= 5 P(A.1) = 6 Q(P(A.1)) = 4 R(Q(P(A.1))) = 16
As you can see this is horrible to work with. Also my formulas are too difficult to read when I combine them and base all results on 1 variable like this:
P(A):= A+1 Q(A):= (A+1)-2 R(A):=((A+1)-2)^2
A.1:=5 P(A.1) = 6 Q(A.1) = 4 R(A.1) = 16
So what I want to do is really like at the index or something else to pass info to other formulas. I know this sounds like array calculations, but is said, that is not exactly what I want. Because I want:
P.x:=A.x+1 Q.x:=P.x-2 R.x:=Q.x^2
A.1:= 5 P.1=6 Q.1=4 R.1=16
A.2:=6 P.2=7 Q.2=5 R.2=25
And that without having to re-write the formulas over and over again.
Is this possible?
Maybe I'm missing something, but what happened to the simple approach?
Mike
Thanks for the extra examples.
@ Mike Armstrong: I don't want to work with matrices as my output format of the sheet should look plain text.
@ Wayne Reid: The first lines are what I need.
P(A):=A+1 | Q(P):= P-2 R(Q):=Q^2 |
becomes:
P(A):=A+1 Q(A):=P(A)-2 R(A):=Q(A)^2
thanks.
