Remarks in programs
Highlighted
Emerald V
Remarks in programs
It is possible to insert remarks in programs - see attached file.
Valery Ochkov
http://twt.mpei.ac.ru/ochkov
Highlighted
Remarks in programs and speed
If it is necessary, that the program worked as soon as possible faster, it is better to write the comments outside of the programs.
See attached file.
Valery Ochkov
Highlighted
Remarks in programs
On technology described above, for commenting the program (vector - line) is possible to use a matrix with one line and with two columns. In this matrix the first element is an operator of the program, and second - textual constant - comment. So only it is impossible to make comments last (returned) operator - program will return in this case not a scalar, and vector. But "if it is impossible, but very much it would be desirable, it is possible!" - see attached file.
Valery Ochkov
Highlighted
Remarks outside programs
The textual constants-note can be used for commenting in outside of the programs.
Valery Ochkov
Highlighted
Nested array as remarks in programs
For the best commenting of the program it is possible to use the nested attays, which some elements have invisible (white) colour - see attached file.
Valery Ochkov
