Rerunning a loop with a condition.
ptc-5008809
1-Newbie
This is a small part of my loop which gives me the value of P.M in the end; which is a
(312 X 10) matrix.
I am interested in calculating P.M with a condition saying (PM<x) it reruns the loop again
incresing the value of xi by 10 each time
Please ignore the error as i have deleated 95% of the table since it was 15 pages long.
If someone could please write a discription or a short example for help.
thanks in advance.
2 REPLIES 2
Was you able to sort things out with your last problem?
http://communities.ptc.com/message/199709#199709
Assumed answered does mean you have found your error in reasoning?
As you PM is the product of a constant and x[i. If PM<x[i and you increase x[i the relation will remain the same! So the while-loop you would have to use will run endlessly. Or did you had in mind to increase the factor in yor PM only, leaving the value to compare with unchanged?
