SOLUTION of non-linear PDE's
Am I correct in stating that Mathcad can only solve Laplaces equation as the default PDE?
If so, then has anyone solved a set of non-linear PDE's in particular mass, momentum conservation equations for conical pipe flow using Mathcad.
I am sure that it can be done using Mathconnex but surely an easier way exists?
Theresh.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
