Scriptable objects
Scriptable objects
How do you add controls such as labels, textboxes, command buttons to a Frame control object?
I've tried right clicking it, double clicking it and attempted to paste them on; all without success.
Scriptable objects
The scriptable object toolbar is not functioning properly in Mathcad 2000 (had the same bug in Mathcad 8). If you want to see how it's supposed to work, switch to Mathconnex and insert a frame, then double click on it and the scriptable object toolbar will pop up. I called Mathsoft a year ago about this problem and then about 3 months ago when 2000 came out. Lousy debugging on their part... Strick
