Select and match
ldante
11-Garnet
Select and match
Hi
How can I select the maximum number  in each column from (m) but  not more than 1  and match this in the "match ?
1 ACCEPTED SOLUTION
ViktorKorobov
(To:ldante)
5 REPLIES 5
The conditions are
Select the maximum number in each column but not more than 1
then lookup (row(match))
Sorry if my explanation is not technical sound as a programmer .
Result should be
ViktorKorobov
(To:ldante)
Viktor
Viktor
thanks
