Greetings,
I had created a test document to practice the CreateMesh and CreateSpace functions.
This was done on one machine with Mathcad 15.
Now, the CreateSpace will not display on a different machine which also has Mathcad 15 and Prime 3.1.
Any ideas as to why?
If nothing is wrong with the set-up, what settings could make this behavior happen?
The file is attached.
Thank you for your time.
P. Quint
Right click on 3D plot (created by using "CreateSpace") and deselect "Border".
It might be a problem with the monitor set-up, I took the following snips from the same laptop just set either for 16bit or 32bit colour resolution.
regards
Andy
Thanks VladimirN.
I don't know why that enabling the border messes with the display, but yeah.
Mark
You're welcome.
Peter Quint wrote:
I don't know why that enabling the border messes with the display...
The problem with the border for 3D plot - it is an old story.
