Shortcut for append column to the matrix
SOLVED
Hello all
From the shortcut list of Mathcad, shift+space can append an extra column to the matrix.
However, I found that it doesn't work for my Mathcad Prime 7.0.
Does anyone know how to fix it?
Btw, pressing shift+enter to append an extra row to the matrix can work in my computer.
Thanks!
Tags (1)
Re: Shortcut for append column to the matrix
Sounds like a(nother) Windows keyboard issue... It is known that certain keystrokes don't work on certain keyboard layouts.
Do you have multiple keyboards installed on your Windows?
Does it work with a US keyboard, or a US-International keyboard layout?
Thank you so much!!
The shortcut works after I used the US-keyboard.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
