If I have a graph generated in MathCAD, is it possible to copy that to a Pro/E drawing? Not as an image, I can do that from Excel.
Hi folks,
In the latest version of the ProE-Mathcad integrations we can generate curves and surfaces in Mathcad and send them to ProE to be used in sweeps and extrusions etc. So say we plot in Mathcad sin(x). We can send the points from that graph to ProE to be rendered as a curve. None of the axis, legends or plot titles will be transfered .. simply the points.
John
If not as an image, then as what?
Vector data. DXF. not raster.
Well, I don't know wnaything about Pro/E, but can you use "Paste Special" and paste as a picture (or metafile, or enhanced metafile)? If you can then you should be able to do that with an Excel graph too though. If you can't, then the limitation to bitmaps is within Pro/E.
How that you generate vector data from Mathcad?
Is that a question?
Mike
You want to copy a graph onto a live 3D model?
Mike
Hi folks,
John
That's a very nice feature. Do you mean Creo?
Mike
Hi Mike,
No I meant Wildfire 5.0, latest release. I am not certain of the story of Mathcad and Creo
John
Cheers for clearing that up.
Good to know that can be done.
Mike
