Shows variable is undefined
SOLVED
Re: Shows variable is undefined
Thank you. My work involves to do a cubic spline interpolation. Should I try with a cubic spline and then use interpolation or, there is a smarter way.
Prime has (among many) a cubic spline function (cspline.)  It will create a function that is an interpolation between knots.
Thank you very much. Should I use as interp(cspline(x,y),x,y,x1)
You never mentioned that you will be after interpolation so far
The spline already IS an interpolation!
There is not much you'll have to change if you want to replace my linear interpolation by spline interpolation.
You also may want to know that Mathcad knows three different types of cubic splines (the difference is the behaviour at the end points).
Highlighted
Thank you very much for your email. My work has many pieces and parts and I am going one by one and approaching it. I have been working for almost 3 hours with this problem and might take some more time also. I myself also am trying to come up with various approaches and I truly appreciate your help towards my concern.
Is there a way to get the absolute values of a vector. I know the scalar part.
One way to do it:
You used try-error statement and mentioned as trying the absolute if not then just return the value. What does this logic signify. And finally, you vectorized the whole to make the output. Can you please tell me why was it done like this. Thank you
Try and catch was used because your matrix contains a cell with a text (upper left) which would otherwise throw an error when the absolute value is applied.
Vectorization is always the thing to do when you apply calculations on a vector or matrix which is supposed to work not on the whole vector/matrix but on every single element of it. In case of this example you could omit the explicit vectorization because Mathcad will apply automatic vectorization anyway but its a good idea to ALWAYS use explicit vectorization when you want it to be done and don't rely an Mathcads automatic one.
