Shows variable is undefined
SOLVED
Highlighted
Re: Shows variable is undefined
Thank you very much Werner_E. I am learning a lot from your help
Thank you very much  FredKohlhepp
I am trying to make a new approach to my work. The problem is one of the parameters has to change after the first calculation step. I tried to make one but it is not working. Please help me through it
I am unable to understand your solution. Can you please explain. My version is 4.0
I think tkoro's post was entered here by mistake.  It does not apply.
I usually set the parameters and then calculate or programing something. Thereafter, I make a graph to show the result. After the making of graph, I sometimes check the effect of parameters because to check my calculation is right or wrong. In that case global = is useful to check the effect of parameters at the same bottom position of Mathcad sheet.
