Silent Install Mathcad Prime 6 using Microsoft SCCM
SOLVED
Guest
Just curious if anyone has had any success deploying Mathcad Prime v6.0 using SCCM. If i install it manually from a command prompt it installs just fine. If i deploy it using SCCM, setup.exe continuously runs (Never completes) but nothing gets installed. I have checked all of the usual stuff, event logs, av logs but nothing is being reported.
Thank you,
Steve
1 ACCEPTED SOLUTION
Re: Silent Install Mathcad Prime 6 using Microsoft SCCM
Solved using this reference:  https://www.ptc.com/en/support/article/CS311318
I hope this could solve original poster's issue also.
in a bat/cmd file:
set PIM_LOG_ENV=C:\logfolder
setup -xml mathcad.p.xml
Mathcad Prime installs successfully now, via SCCM using system account.
4 REPLIES 4
Mathcad Prime 6 is failing to install using SCCM via System account. The Mathcad installer runs for a few seconds then aborts and reports an exit code of "-610". It writes a log file to the install folder in ccmcache that shows an error code of 1622 which is install log failure. Probably the main source of the problem is the XML file has the user profile folders hard-coded to a particular user (the one who set up the XML file), I don't know why it does that.
How can we work around this problem and install Mathcad Prime successfully from the Windows System account?
in a bat/cmd file:
Thank you DNelson! I shall give it a go and see what happens!
