Simple Table without labels
jdesai-2
11-Garnet
In MC Prime if you do Matrices/Tables/Insert table, you get a table with doodles and brackets etc in the headers to each column. How do you insert a simple table with say 2 rows and 3 columns without these headers, or how do you delete these headers and brackets. I want to insert a text table with part numbers. No math calculations
2 REPLIES 2
(To:jdesai-2)
So why would you want to use a table or matrix if you just want to write Text? Just use a Text Box (Ctrl T).
OR, if you intend to use those text part numbers later again, you may use a matrix of text entries ("") and assign it a variable.
Maybe it helps if you give a small example what you'd like to achieve.
DJF
(To:jdesai-2)
Mathcad probably isn't the ideal tool for that.  Everything has a math reason behind it.  However, you can use the Excel Component inside Prime to make a simple table.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
