Simple? numeric + symbolic calculations
MC_BT_18
Hi! I'm new to mathcad and trying to calculate some very simple equations containing symbolics and numerical elements. I know which answer to get, but simply can't make mathcad return the wanted result.
1/2 * cos(v) * p * L + 1/2 * sin(v) * p* L
I look for the result looking like: 0.67 * p * L
I tried searching for solutions for this but can't really find an answer, but it seems so simple that I can't possibly think that what I look for isn't possible?
Any chance there's an easy workaround?
1 ACCEPTED SOLUTION
LucMeekes
23-Emerald I
(To:MC_BT_18)
Mathcad has a numeric and a symbolic processor that work sort of independently from each other. The numeric processor is involved when you type = after an expression. It requires all variables to be numerically defined. It knows about units and conversion between them.
The symbolic processor is called with the right-arrow operator. It accepts undefined variables and always tries to produce an exact answer. Note that 1/2 is an exact ratio. In contrast 0.5 is a number with finite precision. The symbolic processor does not know units. It treats them as undefined variables.
6 REPLIES 6
ttokoro
(To:MC_BT_18)
Solved.
MC_BT_18
(To:ttokoro)
Thanks, although it's not quite there yet. I know this is a more exact solution, but was hoping for a numerical value before p * L. I guess this is as close as I can get?
ttokoro
(To:MC_BT_18)
PDF attached.
LucMeekes
23-Emerald I
(To:MC_BT_18)
See what happens if you change at least one of the 1/2 to 0.5...
MC_BT_18
(To:LucMeekes)
Thankyou!!
I feel so stupid now, that I didn't try that myself. I knew it had to be a simple thing to do, I just couldn't get my head around it..
I'll remember this "trick" for next time!
LucMeekes
23-Emerald I
(To:MC_BT_18)
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
