Simplify a complex program??
ptc-3935425
Dear all,
I have a requirement for iterating the equations and derive the results.
Please see attached file.I have tried to explain with some points below.
There are two separate headings in the file.'GIVEN DATA' and 'EVALUATION'
Under 'EVALUATION' you can see two different topics 'UPPER BOOM' & 'LOWER BOOM'
'UPPER BOOM' will have 7 equations written and 'LOWER BOOM' will have 4 equations written.
You can find similarities between all the equations.(a kind of iteration)
All the outputs are given in singular matrices.
I beleive, the method I have used to solve these equations is not the best one.
I'm looking for the best way to solve in terms of easy steps. ie . reducing the number of steps.
I guess, since all the equations has some similarities, it can be formed a loop so that I get the results in a simplified manner.
Note : All The singular matrices denotes X,Y & Z values. and Z value will not at all in use.
I'm expecting the results in table format. I.E :results of output in X & Y Is it possible.???
Please revert back if you have any questions.In addtion, I have attached the PDF file also.
Kindly help
Forgot to metion a point,In 'GIVEN DATA',you can see 12 singular matrices (x & y values)
i.e : CL1,CL2,CL3 until CL12.
I beleive these can be put together in a combinations 3x12 matrix????
However the best way to solve!!!!
Something like the attached?
