Simultaneous equations not solving MathCad 15. Normal Distribution/Weibull
KonradS
3-Visitor
Hello Everyone,
im trying to match normal and weibull distribution.
The probability density and inverse cumulative probability distribution for probability of 0.25 for both distributions
should be equal. I have to find two Weibull parameters (3rd parameter = 0). I´ve tried solve block but its not working.
Can someone help me?
1 ACCEPTED SOLUTION
You'll have to define a specific value for x. You can't use a range here.
6 REPLIES 6
"Find" alone will not do anything! have you tried "Find(k,u)=" ?
Better you attach your worksheet instead of a pdf. You'll have to zip it to be able to attach it here in this broken forum.
Yes, i have
KonradS
3-Visitor
(To:KonradS)
That is the honest truth.
Thank You.
LucMeekes
(To:KonradS)
Try your luck with this:
Maybe you can evaulate W(x) symbolically and then display the result numerically. (Mathcad 11 can)
