The slopes must be identical for the lines to be parallel. 2/5 and -2/5 doesn't cut it.
For perpendicular, the slope must be the negative reciprocal. 2/5 & -5/2 for example.
How do you graph them? There are many ways. First, tell me if you have StudyWorks and I can shoe you the easiest way. Typically, folks like the slope-intercept form. You can find a point, use the slope to find another, then draw the line.
> Find the value of b in 2y = -7x + 3b so that the y-intercept of its graph will be (0,-13)
Put it in slope-intercept form and solve the piece you you want.
2y = -7x + 3b ------------ Not quite slope-intercept form. - Divide by 2
y = (-7/2)x + (3/2)b --------- That's it. The y-intercept is (3/2)b.
We want (3/2)b = -13 Solve for b...
Just for the record, this is an unfortunate problem. Since the slope-intercept form (y=mx+b) normally uses the parameter 'b', it is kind of confusing to have an unknown quantity named 'b' in the problem. Teachers and authors should choose better names so as to be less confusing. I think.
