Solve diagonal resistance of resistor mesh.
SOLVED
ttokoro
Peridot
R(1*1)=1, R(2*2)=3/2. How about R(3*3),R(4*4) and R(5*5)?
Re: Solve diagonal resistance of resistor mesh.
Approximate expression of diagonal resistance of x*x resistor mesh by Mathcad Prime 6.0.
Tags (1)
18 REPLIES 18
May be it will help you!May be it will help you!
Tags (1)
Approximate expression of diagonal resistance of (0,0)-(x,x) of infinity resistor mesh by Mathcad.
Tags (1)
The answers from 16x16 mesh to 30x30 mesh.
Tags (1)
4*4,5*5,6*6,7*7,8*8=
Tags (1)
Resistor mesh of 50x50
Tags (1)
Resistor mesh of 200x200. This is my limit of evaluation of Mathcad Prime 6.
Tags (1)
250x250
Tags (1)
Solve diagonal resistance of resistor 2*3 mesh. This is good question for university students.
Tags (1)
Tags (1)
Tags (1)
Tags (1)
A. J. W. Duijvestijn, "SIMPLE PERFECT SQUARED SQUARES AND 2 x 1 SQUARED RECTANGLES OF ORDER 25" Math. Comp. 62 , pp. 325–332, 1994.
Tags (1)
R2D(10000*10000)=11.804
R2D(20000*20000)=12.687   ohm.
Tags (1)
Diagonal resistance of resistor mesh 50000x50000 is 13.854 ohm. 20 min. to solve the mesh.
Tags (1)
Now all 2D resistor mesh electric circuits are solved. Not only diagonal resistance but also any two point of nodes of the circuit.
