Solving ODEs in mathcad prime 2.0
Asad
6-Contributor
I need help solving these ODEs. File is attached and the ODEs to solve are at the bottom of the worksheet.
Thanks! Help is greatly appreciated.
3 REPLIES 3
24-Ruby V
(To:Asad)
Prime can solve ODEs only numerically.
You have to use a solve block with odesolve and you have to provide initial conditions.
Furthermore you have to write d/dz P(z) and not just d/dz P(z).
Additionally you can't write v^2 (z) as this is interpreted as v^2 * (z). You have to write v(z)^2.
I spot functions v,x,z and rho, all dependent on z.
But what about the expression d/dz (c.p*T.f) ? Is there a fitfth function dependent on z (which one - c.p or T.f - neither is defined)  and you have only four equations??
Also it may be problematic that you have a function x but x is also used as a variable (x=0013)
Asad
6-Contributor
(To:Werner_E)
x is a variable for molar fraction, it is not a function. And the variable x is itself dependant on z coordinate.
Equations are there for calculating cp(z) and Tf is to be found, it the temperature and tells the temperature along z axis.
Yes four equations, for v(z), x(z), Tf(z), and P(z).
The other variables such as h, cp, rho are also dependant on z coordinate but we have direct equations to calculate the values at any point z.
24-Ruby V
(To:Asad)
And this means that x actually IS a function of z but you had used x as a single variable with the constant value 0.013
And so you have to provide those functions! None of them are defined in your sheet as far as I can see!
And as already written you also have to provide initial conditions!
