Solving a multi-var equation of matrices
JonD1
I am trying to get a matrix of numeric answers for a single variable in a multi-variable equation. The equation can't be rearranged symbolically for the variable in question. My desire is to input a matrix of values for two of the three variables, and get out a single-column matrix (array?) of values for the last variable.
Attached you'll find the equation and a subset of the data I'm trying to work with (there are hundreds of data points). Page two is a failed attempt to try it in a solve block (tried both Find() and Minerr() operands). [MathCad 2001i, Windows 2000 - I have access to MathCad 14 on a Windows XP machine if necessary]
~Jon
8 REPLIES 8
Plot graphs to see the problem! See attached.
Alan
Note: I've edited this to attach a corrected workfile.
Message was edited by: Alan Stevens
Saved 2001i in yellow
jmG
Thank you for the solution! It doesn't work in 2001i, but does work in later versions of MathCad (I tried it in MathCad14).
MikeArmstrong
(To:jeanGiraud)
jmG
Jean,
RED in Mathcad 14.
Mike
Can also use Mathcad's root function. Two methods in the attached worksheet, saved in 2001i format (but not tested in 2001i).
Alan
Thank you both! Both are great solutions. Problem solved.
MikeArmstrong
(To:AlanStevens)
Alan
Alan,
Is that worksheet posted in the correct thread?
Mike
Mike wrote
"Is that worksheet posted in the correct thread?"
Mike,
I think so. Compare the name of the attachment with that of the original one posted by JonD. Also, JonD seems happy with the solution!
Alan
