Solving an equation
ygormarca
Solving an equation
Hi there,
I have the equation below which Vout and Io are variables and I need to isolate Vout from the right side of the formula, but the function is too large to display.
I could manually isolate Vout, but I found a third order equation that again MathCad could not solve...
The problem is that I have two variables, Vout and Io and I have to plot a graph of Vout/Vin in function of Io.
8 REPLIES 8
The equation is too hard to read from the graphic.  Enclose your worksheet please.
Regards
Terry
Sorry, I just uploaded a worksheet.
Thank you
LucMeekes
(To:ygormarca)
What's the circuit and what are you calculating in the circuit?
(How did you get to this formula?)
Or did you just type this entire formula in from your head?
(I'll accept a picture of the schematic, worksheets preferrably saved as Mathcad 11 .mcd)
ygormarca
(To:LucMeekes)
Hi Luc,
Well, it`s a static gain of a converter.
I think the schematic would not help in this case because it is too complex to understand it quickly. The problem is the math behind this equation.
I uploaded a worksheet in mathcad 11 if you want to see.
LucMeekes
(To:ygormarca)
Is this what you are after?
(Still I think it would be better to start from the design)
ygormarca
(To:LucMeekes)
The problem there is that qdcm cannot depend on Vout, that`s why I tried to isolate Vout from the expression.
ygormarca
(To:LucMeekes)
What you`ve done is correct, but if qdcm doesn`t depend on Vout anymore, it`ll give just one curve and that`s what I need.
LucMeekes
(To:ygormarca)
I don't see how qdcm could be independent of Vout, it's in there!
The only way I could imagine it drops out, if it drops out together with Vin.
Once again: how did you get the expression for qdcm...?
