Spline Fitting & Integration
Dear All,
I am having trouble with the attached file. The `Rds` matrix represents the `X` values of a graph, while each of the columns in the `Thr` matrix represent the `Y` values of the graph. I want to fit a cubic spline interpolation to each of the columns of the `Thr` matrix in turn, find the area under the curve i.e. the total thrust for each column and then plot a graph of the each thrust against its corresponding column number.
Can anybody help please.
Neil Moran
Dear Nile,
I hope that my files help you.
See also the messages in the forum Probability & Statistic.
Valery Ochkov
http://twt.mpei.ac.ru/ochkov
Hi Valery,
Many thanks for your files, which I have had a look at. But I am still having trouble trying to achieve what I want. I dont seem to be able to create a range variable in order to index each of the columns, one at a time
Does anybody have any more suggestions please?
Many Thanks,
Neil Moran
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
