I'm familiar with using the spline and interp functions in Mathcad to use spline-interpolation of a dataset. Considering a situation where the dataset is noisy, I'd like to be able to fit a spline of n-degrees of freedom rather than creating a spline that goes through all datapoints. I can't find any help in the Mathcad documentation so input from you guys would be much appreciated.
I can see it exists for Matlab: File Exchange - MATLAB Central
In Mathcad 15, go to "Help", "E-books", "Data Analysis Extension Pack", Under "Non-parametric fitting / Interpolation", choose "B-Splines and Least-Squares Splines". If you are using Prime I'll have to figure out where the information is.
I'm afraid no E-books are available for me, can it be attached here?
Which version of Mathcad are you using?
Here's the relevant section, but if you don't have the Data Analysis Extension pack installed then spline2 will not work.
Found it; just had to browse to the handbook file. Thanks man!
Must be spline interpolation!
Not if it's a least squares spline.
