Stae range Logic
jeanGiraud
1-Newbie
Stae range Logic
Adapt for your project limits ... a, b instead of 1, 2
jmG
6 REPLIES 6
I did intentionally spelled wrong , to see if PTC had considered
my complaint about the originator to remove his own prime
discussion ... Like a farth, you heard it, can't put it back !
Apparently can correct but not remove ... limited logic .
jmG
... even more stupid :
could correct the spelling in my own
reply but it does NOT show corrected.
"To upload an image, you must insert it in the context of a discussion. " = incorrect
"To upload an image, you must insert it in the body of the text [of a discussion].
"incorrect" is incorrect again ... red font underlined black , what's that ?
jmG
... now it shows corrected after an "invisible eternity"
This site does a lot between the user and PTC , but nothing
that tells they are in conversation and when it ends.
... Oh !
It never underlined red while composing , and I was slow [intentionally]
I reads it back underlined red and spelling correct
It explains partially why Mathcad goes so slow if the PTC community
is open and minimized in the application bar. It looks like a "time
shared conversation" ... what I mean here conclusively, is that if
PTC community is open it allows my box only the time PTC gives.
Can't evaluate the calculation time PTC community is sucking
from calculation , but it looks in the range of slowing down
Mathcad or any other application by a factor of at 2 or >.
Conclusion: can't work anything in the box if PTC is open ,
or work at very low speed. So, assume working for a visitor,
you need Mathcad working but very slow. That PTC community
is slow by itself is one thing, but slowing the remote collab
that has no justification.
jmG
RichardJ
(To:jeanGiraud)
That has it's good points and it's bad points. One thing I found very irritating on the old Collab was when someone started a new thread, and then after others had replied they deleted their original post. I have no problem with people deleting their responses (I've done it myself!), but I do have a problem with people creating headless threads.
Agreed Richard,
it has +++ & - - -
At least and for an unknown reason and unknown who,
the spelling has been corrected in the PTC page.
Maybe like in Akiva, the responder just had to correct
the spelling of the originator.
Whatever, the compobox is not WYSIWYG.
jmG
