Summing function Wm(time,a,b,c,d) from m=0 to m=n ?
SOLVED
JXB
Alexandrite
To all,
I am sure I saw something about how to do such thing but I cannot find it so needs some pointers
I have a function (see attached mcad sheet) Wm(t,am,bm,cm,dm) where t is time and am,bm,cm,dm are coefficient valid for equation m
I need to do sum of Wm from m =0 to n: Capture.PNG but I am struggling with indices in mcad
Coudl anyone refreshe my memory on this summation? It might be something with "dicretizing" the time 't' if I recall
JXB
Re: Summing function Wm(time,a,b,c,d) from m=0 to m=n ?
Thanks to all for the help. Moving on to the next bit of the tool....
14 REPLIES 14
Like the attached?
I have change t from a range variable to a vector and also removed the units s the program works.
The attached should help.
Alan
Looks like Mike just beat me to it!
Edit: Just noticed that your original file was a .mcd, so I've added a .mcd version here.
Mike: In your file the definition of Wm still contains tdm < t > tdm+Nm/2fm. I suspect this should be tdm < t < tdm+Nm/2fm (though I could be wrong!).
Hi Alan
Thanks for the help. Am I correct to say that the Sum only works for a specific t value and not a range of t. Using Mike suggested method, I reckon that one needs to use two range variables
i for the vectorised time t
m for the number of coefficient (a,b,c,d) to consider
Alan
Hi Alan,
I was a little unsure on this myself, but the tdm condition ' < t > tdm+Nm/2fm ' does return a few 'True' evaluations so I left it as it is. JXB can you clarify?
J B wrote:
Hi Alan
The sum as written only works for a specific value of t, but you could include this sum within another that summed over the values of t.
Alan
Mike Armstrong wrote:
Alan
Hi Alan,
It will evaluate to "true" only when t is greater than the larger of the two conditions.
Alan
It depends on what you are hunting for. As I suppose from the inserted pic you want to define a function for the second derivative of x like shown below, but I may be wrong.
And of course you may "sum" over t by using an integral.
But to be honest its unclear to me what you are really after.
Alan
Hi Alan,
Alan
Agree.
Which is does from row 951 onwards
I think the way you have it is the correct way, but confirmation by JXB would be beneficial.
Clarification for < t > statment. I changed to an OR statment. Will attahced a ver2 of the mcad sheet soon
