Swap Matrix Rows and Columns
atbarajas
I have a 42 x 42 matrix, and I need to swap some rows and columns. Does anyone know how to do this? I know you can do it fairly easily in Matlab, but I haven't successfully found that feature in Mathcad.
Thanks, and any help is appreciated.
Talina
Nevermind. I found out that I could use the "augment" function to switch the rows, and then I took the transpose of my matrix, and used "stack" function.
MikeArmstrong
(To:atbarajas)
Why don't you post an example of the problem. This way you are much more likely to get a response.
It also clears the problem up.
Mike
