Switch user interface language to german
hkatgert
6-Contributor
All,
I did install the German version for Mathcad 15 M050.
Starting the application I can only choose the English language.
The German language is not present in the list to select in Tools>Preferences>Languages.
11 REPLIES 11
@hkatgert wrote:
All,
I guess you have to download german installation package from https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=MCD page.
Martin Hanák
hkatgert
6-Contributor
(To:MartinHanak)
Hi Martin,
Thanks for your reply and info.
I did download German, but no luck.
Brg,
Hans
@hkatgert wrote:
Hi Martin,
Brg,
Hans
did you unistall 1st Mathcad 15.0 installation and then installed german Mathcad 15.0 ?
Martin Hanák
@hkatgert wrote:
Hi Martin,
Brg,
Hans
I installed german version of Mathcad 15.0 M050 in Windows 7 English ... when I start Mathcad I can see german command in its UI.
Did you uninstall english version before installing german version ?
Martin Hanák
hkatgert
6-Contributor
(To:MartinHanak)
Yes I did, because I'm supporting a German guy to have German language active.
I followed procedure in
https://www.ptc.com/en/support/article/CS320741
That one solved the issue.
I will also try your proposal with culture setting example.
Syntax for German,  "/culture.de-DE" ?
Thanks for your input.
Hans
LucMeekes
(To:hkatgert)
Did you chioose 'language during installation' to be German, or did you actually install a German language version of the application. There's a difference between the two...
Try installation again and see what you can choose during installation to find out. (No need to rerun the full installation, you can abort it before it actually starts to install.)
hkatgert
6-Contributor
(To:LucMeekes)
Hi Luc,
Unfortunately I don't see any option to choose German Language?
-MFra-
(To:hkatgert)
I had the same problem in 2016. Thanks to M. Hanak's suggestion, everything went OK and M15 is also fine. See below: (instead of "culture:en-US", you should write: "culture:de-GE"
Ubuntu may ask if you want to update or add components to your current default language when you first open the dialog. Click Install to go ahead and install the additional components, or you can click Remind Me Later to wait as these will be installed automatically when you add a new language.
Please send your issue by using "Mathcad Support Center":
https://support.ptc.com/support/mathcad_supportCenterEnterprise.htm
hkatgert
6-Contributor
(To:VladimirN)
All,
I did create a ticket and issue is solved by PTC support with link below:
I will also take the other ideas in account to have multiple/easy  solutions.
@VladimirN @Knowlton @MartinHanak @-MFra- @LucMeekes
Thanks for all your input.
