The question : Need help with Symbolic Evaluation the above.
Thanks in advance for your time and help.
This should be simply (x-1)/x.
There's only one term in the summation, since n runs fom 1 to 1.
And with n being 1, the multiplication contains also only one term, since k runs from 1 to n=1.
So with k being 1, the one term is (kx-1)/kx, simplifies to (x-1)/x.
And that is the last line from the symbolic evaluation above
But ok, I understand your point that you do not require mathcad for this. However, when you try to evaluate the expression in M15 you get
and probably this was Loi Le's point in posting the thread.
or 1-1/x. Of course you are right and if you set the upper limit n in the product to 1, Mathcad agrees with your statement 🙂
But I assume its only a simplified example and the upper limit of the outer sum is subject to change.
Nevertheless muPad should not have that many troubles in simplifying this one. It seems the the inner product is evaluated first with an arbitrary variable n, which results in a lot of distinction of case and only after that the outer sum is applied and the branches are not resolved and simplified thereafter.
Here are some partial results using MC15:
If you take a look at the Prime 2.0 answer, there are four conditions to be met for the final result. I wouldn't argue with the first two, but the last two are that 1/x must be greater than or equal to 1, and that 1/x must be less than or equal to 1. Then the only possibility is that x=1, and the answer is zero. Wrong!
Incidentally, the Maple engine in MC13 and earlier gets the answer of (x-1)/x in a fraction of a second. I wish we still had the Maple engine
Wrong? Why? Akward, clumsy, unhandy and unuseable, yes!
Its true, the final result refers to x=1 only and it would be zero. But most of the other results using the Gamma function will simplify to the correct result 1-1/x, too, as in the MC15 example I posted above. Obviously "simplify" is not applied in expressions inside the if conditions.
Fully agreed, I second that for a multitude of reasons!
OK, I guess strictly it is not wrong. It just an extremely special case that should be simplified to zero, and is a subset (consisting of one element!) of a much more general case where the answer is (x-1)/x. It's about as close to wrong as it's possible to get without actually being wrong!
One additional spot in evaluating the inner product only - great difference if we use assume or substitute!
"assume" is applied during evaluation of the product, "substitute" obviously only after and Mathcad/muPad is not able to simplify the multitude of branches and it seems to me trhat it even don't try to do, otherwise at least the expressions with the Gamma functions have to be simplified.
Hello, again.
The question : Need help with Symbolic Evaluation, the above. ( MC14_M020 ).
Best Regards.
A sum from 1 to 1 can be omitted as can a product from 1 to 1. So you don't need Mathcad to get x/(x+1), right?
Hmmm... I think there is something more than this sum, that you whant to show. Am I wrong?
Best Regards.
So whats the problem?
Many thanks, Werner.
Best Regards.
