I try to create a symbolic matrix (in my example, the matrix RES ).
The problem is that I cannot have the result in the form of a matrix, the only way to obtain what I want is to say that RES is not a matrix and is depending on two others variables corresponding to the indexes of the "matrix" (RES2 solution in the attached file question.xmcd). However, I need to use this result after and I need to have the result in the form of matrix.
How can I do to obtain my result in the form of a matrix ?
Thanks !
You cannot index a function at its definition. Mathcad is looking for the name of a variable to index.
The second function definition does work as it does a number of summations that return a single value as a result of the function.
You can define a matrix that uses this function. Is this what you are after?
Warning. by default Mathcad indexes matrices from 0,0 unless you redefine ORIGIN worksheet variable.
Cheers
Terry
Cheers
Terry
Thanks for your response !
The answer would not be complete now we know the intent.
You can define the matrix with a quicker notation using the values of r and s you defined.
In this case a name is used in the definition so you can use indexes
Remember by default matrices start at index zero.
Cheers
Terry
This is exactly what I wanted, thanks !
But I still have a question, if I want to keep U and V as symbolic variable, the only way to obtain the matrix is to create each component "manually" as in your previous response ?
JUF
Not sure I understand your question.
U and V are variables in scope for the function RES2 definition.
V is also a variable in scope for function MAT2 definition.
I don't want to call them symbolics as this has another description in symbolic arithmetic.
U and V in definition for RES2 are set to the values 10 and 31 only in the definition of the final matrix in one statement.
I want to have this :
where MAT(U,V) is a matrix (of function) and U and V are variables in scope for the MAT function. After, I will used this matrix for different values of U and V but for now I want keep U and V as vrariables.
My question is : can I do something like the print screen below?
Or do I need to define each component of the matrix MAT as it's done in the previous printscreen ?
(There is the reply with printscreens, sorry)
You cannot do this as Mathcad will not let you define a function with index values.
You either do as in your matrix method which gets cumbersome with big matrices..
Or use a small program to get around it.
Cheers
Terry
The solution with the for loop works perfectly !
Thanks a lot Terry, It's really helpful.
Cheers,
Julian
