Symbolics Help
SOLVED
Participant
Symbolics Help
Working with symbolics is not my strong point. Need a little help with questions on the sheet. Based off of Dr. Alan Stevens critical thickness insulation work. Mostly symantics ... so driving me crazy.
Re: Symbolics Help
ElSid wrote:
Did not understand the second part
AlanStevens wrote:
--> Replace T.sat with either T.s or just Tsat (i.e. no subscript) It will then result in T.s - T.air rather than -(T.air - T.sat ) .
See attached.
Alan
11 REPLIES 11
Re: Symbolics Help
One thing you should always remember when using the symbolic processor is that it does not make implicit assumptions like you do. If it doesn't do what you expect then a liberal dose of the "assume" keyword can work wonders
Re: Symbolics Help
Arrg! I had the R and t>0 on a previous section ... thanks for the catch. Is there a way of forcing the 2pi to the numerator? What about the negative sign?
Re: Symbolics Help
Solve first, then simplify to get rid of the weird formatting, then force the ln formatting.
Re: Symbolics Help
Think of P/2pi as P1 and solve for P1. Then set P:=P1*2pi ->
Alan
Re: Symbolics Help
Interesting observation. I wonder why that makes any difference. I would expect the formatting to be independent of the choice of variable name.
Re: Symbolics Help
Re: Symbolics Help
See attached.
Alan
Re: Symbolics Help
Revisitng a post with a file that I had working in MathCAD 14 and for some reason will not work in MathCAD 15 M030. Hoping the Collab can help. Problem starts with equation 5 where it appears I can not longer define a variable based on a symbolic. See screenshot
Re: Symbolics Help
Thats "normal" (nevertheless strange) behaviour that you dont see a symbolic result when you use a symbolic inline evaluation in an assignment.
Simply evaluate P.F later and you will see the correct result.
You used a font which seems not to be installed on my machine, so the nominator is shown as a small rectangle.
Depending on how wide you'd like your sheet to be spread you might consider changing that.
