Symbolics...what am I doing wrong?
DJF
Alexandrite
Using symbolics (4.0) to develop an algebraic solution - but I get more than I bargained for.
I can't seem to find an assume or other feature to simplify this.  I'm assuming I need to specify real solutions or similar but that doesn't seem to work.  What I'm expecting to see is:
Any ideas?
Tags (1)
6 REPLIES 6
Re: Symbolics...what am I doing wrong?
What are you doing wrong?
Using Mathcad for symbolic solving!  Smiley Wink
I agree with Fred ;-)
I assume that j should NOT denote the imaginary unit, right?
Here is my best attempt - I had no luck in persuading Prime to return only the real solution (the one with _x=0)
I don't, but then... I have Mathcad 11:
Still disappointing when we expect something more simple like this
Disappointing? This is disappointing:
And it doesn't matter if the brackets () are there or not.
Seems that uncle Wolfram interprets PR as text which he doesn't understand and not as a two letter variable name.
I have not much experience with Wolfram Alpha so I don't know if its possible to use multiple letter variable names with some special syntax but from what I have seen so far it looks like WA would only accept single letter names, alpha beta, etc and indexed variables but only if the index is a number.
I would have guessed that using assume or simplify Maple in MC11 would be able to do the job, like other software do out of the box (here with Geogebra CAS):
