Hi everyone.
I am doing a simple calculation, but I have problems in the temperature units, which generates erroneous results.
A quick solution in this case would be to work the temperature without units. However, is there a way to work with units in this type of equations without getting wrong results?
Thanks for the help
Here's a confirmatory worksheet ...
Stuart
Great. Thank you very much Stuart.
