The Three Reservoir Problem Revised In Prime
SOLVED
Newbie
I converted an old Mathcad 12 template to MC Prime 2 see attached but for some reason the solve block is not returning a solution. Can anyone see the problem - is it something to do with units or has the solve block been set-up incorrectly for Prime?
Regards, Mark
Tags (1)
1 ACCEPTED SOLUTION
Re: The Three Reservoir Problem Revised In Prime
Have a look at the attached.
Alan
10 REPLIES 10
Hi Mark,
Can you upload your instant worksheet for Mathcad 12?
Within the Solve block shouldn't ZA be Z(QA), ZB be Z(QB) etc?
Alan
Vladmir;
That's my problem I cannot find the original version 12 file. I converted this some time ago and it would appear that I have changed some key aspects from the original but the methodology looks sound to me.
Mark Buckton wrote:
Vladmir;
Could it be the one of yours in this thread?
http://communities.ptc.com/message/30412#30412
Highlighted
Alan;
What you suggest is logical and I have done what you have suggested but now Mathcad is complaining that Ep needs to be a function but a function of what? It cannot be a function of flow rate as there are 3 independent flow rates? Any more suggestions?
Mark
No that is still not the original file version 12 file that is an altered version that I was playing with but never completed.
Alan
Mark Buckton wrote:
Alan;
Mark
You probably forgot to change Z.A for Z !?
Just thought as that old file show the same error of Z.i not being functions as your Prime worksheet
