The feature of "Ctrl+Shift+J" in MathCAD is missing in MathCAD Prime 3.0
SeanYing
Visitor
[Ctrl] [Shift] J Type characters inside brackets as in chemistry notation in MathCAD 15 or the previous version
but I can't find the same feature in MathCAD Prime 3.0.
Please tell me where it is, or I recommend to adding it in the next version.
Re: The feature of "Ctrl+Shift+J" in MathCAD is missing in MathCAD Prime 3.0
We have not
Ctrl+Shift+k
Ctrl+Shift+j
Formula+Ctrl+Enter
in Prime
I would point out that even though the shortcuts are not in Prime.
You can get brackets into the definition through a different approach.
Just type in doubles quotes in your worksheet and begin entering your expression as text, then when done remove the quote marks and it your text string will revert to a Math region you can use.
The subscripts here are unicode characters ( Windows Character map)
Here is a useful blog written regarding how to enter subscripts/supersripts in text + make use of special characters from Unicode in Mathcad.
http://blogs.ptc.com/2014/04/30/to-err-is-human-to-work-around-divine/
Simply type a double quote then type the character in between the double quotes. Now click to the right of the first double quote and hit backspace to remove the double quotes. Voila, you have a math region! - See more at: http://blogs.ptc.com/2014/04/30/to-err-is-human-to-work-around-divine/#sthash.UiWTaTwu.dpufhttp://blogs.ptc.com/2014/04/30/to-err-is-human-to-work-around-divine/
Voila - I cann not do it in Prime 3 with Win 8.1
