I want to find out the intersection between these 2 graphs, how can I find it?
Thanks.
Here's one way:
Good, thank you very much.
I really needed a solution quickly because tomorrow I have to present a project and I wanted to find the frequency at which the two graphs intersect.
So, thank you very much for the quick reply.
can you put a Mathcad file?
You missed a j
The symbolic answer can also be found:
Obviously, it's the top one of the two...
Success with your presentation!
Good.
Thank you very much!
