This function is undefined at one or more of the specified points.
ptc-4346041
It' my last error and i don't understand, it's very important for me.
The eroor is on the graphics :
PhaseofHH8(f16,tpas2,tm,sa)
Something, can to help me, please.
Thank's in advance.
Olivier
3rd attempt at posting worksheet
the problem arises because the first value of TF591 is 0 implying both Re and Im are 0, but angle(x,y) is undefined at x=0 and y=0. The simplest solution is to redefine angle to check for this condition and return an arbitrary value (0 is as good as any) when it occurs, otherwise return the normal result of angle(x,y), eg
angle(x,y):=|0 if x=0 and y=0
.................|angle(x,y) otherwise
Stuart
I think understand that you say to me but Why PhaseofHH81(f16,tpas2,tm,sa) and PhaseofHH8111(f16,tpas2,tm,sa) are correct ?
Are you sure of your response ?
Should I remove the 0 ?
do you can modify or to explain me in more detail that should I do?
Thank you
Positive. You don't calculate them, you calculate PhaseofH81 and PhaseofH111 (one H not 2). See attached.
Thank you
No need to remove the 0, just redefine angle to cater for the special case of x=0 and y=0
Stuart
PS: I've tried posting a worksheet showing the modified function, but the PTC site is failing to respond properly ...
I wait the worksheet because i don't saw the error.
Thank you
